Not sure if your still around...but I am wondering how the arms are holding up. I'm on a budget, and was thinking of getting the doorman or moog bars, but have heard they don't last. Let me know...thanksdavidsf wrote:Yes...it's a more or less constant higher pitched sound...not loud..but noticeable...and only when the drive train is under a light but steady load. I'm fairly certain it's gear whine from the rear differential. Wish I could post an audio file here but that best describes it in words. I've seen a few other pathy owners complain of the same. If under warranty, the dealer appears to replace the differential.
After thinking about it more, my theory about why this sound appeared after replacing my trailings arms is that the new stiffer trailing arm bushings are simply conducting much more of the whining sound (which was there all along) to the frame...to the body..and to me up front. I'm not too concerned (yet) because it only shows up under certain driving conditions, but if I were shopping for a used vehicle and heard this, I'd wouldn't touch that vehicle. As suggested by Ozzie (thanks), I may back-off the bushing pre-load a bit and see if that makes a difference.
BTW - I replaced the trailing arms with Dorman 905802, 03 and 04. The original bushings were totally shot...especially the lowers.
Thanks for the quick reply. One more question. Did you do just the lowers? Or uppers also?davidsf wrote:Yes...am still around. The RTAB's are doing just fine. The whining sound went away after a few days. My guess is that either the rear end settled in after being jacked up and that put things back in aligment...either that or the new trailing arms slightly changed alignment to expose a high spot on the differential gear and that wore down pretty quickly after a few miles of driving. In any event, it's all fine now. Inexpensive long afternoon project using after market RTAB's with pre-installed bushings. Impact wrench strongly advised...and even with that you may end up having to saw some of the nuts off with a cut-off saw. So suggest you have replacement nuts on hand....hardened steel ones from a good hardware store or the dealer.
How important is torquing with all those standards?Chuck Tribolet wrote:The trailing arm bolts are supposed to be tightened with suspension loaded, including a half tank of gas and the spare on board (in the cargo compartment over where the spare goes underneath is fine, and makes things easier). The easiest way to do this is to support the rear with a floor jack under the diff.
Chuck
