Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Thu Feb 21, 2008 3:51 pm
Sounds like the guy you bought it from already knew about the problems, and just cleared the codes before you bought it. A little bit unethical, but buyer beware.Having said that, I suspect you have one or more bad O2 sensors. This is a common problem on these vehicles. Nothing to get worried about, but it means more money of course. If you go to the dealer to have them replaced, which I suggest you do, then make sure they flash, or reprogram, the ECU. It should be free of charge. There is lots more info on this forum regarding the O2 sensor issues by the way, so you might want to do a search. Good luck. By the way, how many miles on the truck?
