gordon.su »
https://forums.nicoclub.com/gordon-su-u219215.html
Tue Apr 30, 2013 11:33 am
Hey NICO,
I beleive I have a common problem with many other pathfinders and QX4's I was wondering if you could share some insight on how you solved this problem(read below)!
I have a 2001 Infiniti QX4 with close to 220,000km.
Since the summer before I noticed my QX4 gets really hot in warmer temperatures (18-25 degrees celcius) after the engine runs for 20 minutes or more.
The thermostat will ocasionally go close to the very top. This happens especially when I am stuck in traffic bumper to bumper. The thermostat goes up even faster when I turn on the AC in the car.
However if I am driving and higher speeds 60km/h+ it seems as the air going into the radiator will cool down the car, but again if I stop for awhile in traffic the thermostat will climb again.
Some instant remedies I used this far was by turning the heat in the car to the highest settings, which can get very uncomfortable, it is strange even when i turn off the heat the heat still appears to be coming out of the vents.
I've been able to get away with it the 2 summers as I was ocasionally driving in the summer but now that I am working which requires a farther commuting distance and everyday I am stuck in traffic for more than 1 hour, I am affraid on a hot summer day I might not make it back home in traffic in warmer wheather with summer approaching.
some other interesting notes:
- coolant was leaking last summer, but after adding in some solution into the radiator it magically stopped
- my radiator cap appears to be worn out - I looked in the FAQ i am ordering a new one but am not convinced that will be the full soltion to my problem
- could it be my radiator needs to be replaced? - is there a way to find out whether or not it will solve my problem?
- coolant was topped off
