1wcoleman »
https://forums.nicoclub.com/1wcoleman-u227134.html
Mon Nov 04, 2013 6:22 pm
Heat/Air works, all lights on Climate control seem to work, will only blow out of center and side vents, will not switch to Defrost or Floor. I am guessing something is not allowing the doors to switch in the heater.. Is this Vacuum controlled or electrical? Cooler weather setting in and no time for lack of defrost.. Confused as all strings say DEFROST is default, but appears mine went to vent or not in default mode... Unplugged battery overnight and reconnected just to try resets... No change.. Any help out there?
