Great, i have an oil change coming up in a few weeks, guess ill change to a high mileage.Towncivilian wrote:First one is the rear main seal. Clean up the area and see if it is still leaking. High mileage oil may slow down this leak, since high mileage oil contains extra seal conditioners. I would recommend Valvoline MaxLife.
The second one may be oil dripping from a valve cover gasket. Make sure all of the valve cover screws are tight.
Thank you TC
