2001 QX4, the automatic climate control blows through the face vents only, regardless of which vent position is selected on the display. Also, selecting full-hot does not deliver hot air even if the engine coolant is warmed up.
Additionally, the A/C is not blowing cold, when I hook up my gauges to the system the high side never moves (stays at static pressure, even though it sounds like the compressor is kicking on and the low side pressure does draw down a little. I evacuated the sytem and added refrigerant. Could the compressor be too weak to build pressure even though it's running?
