2001 QX4 lights
gixxerboy
Car: 2001 Infinity QX4
Can anyone help ??
Just inherited car with this issue: driver side low beam light is out but the high beam works. Is this just a bad plasma bulb or a balast ?
Thanks
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
install the good low beam bulb into the side that doesnt work and see if it turns on, if not its probably a ballast.
gixxerboy
Ok sounds good. thanks.
QX4dahuneys
Car: 2001 Infiniti QX4 - 2003 Honda Accord LX
The high beam is separate from the xenon charged low beam. The high beam is halogen. Like nissandoms47 said, pull the good HID bulb out from the good side and place it on the bad side and see if it comes on. If it does, then you automatically know it's your HID, if it doesn't come one, it's your ballast. If it's your HID bulb, let me know and I can direct you to a very good person who sell's the HID bulb part for your truck, I had my HID bulbs replaced about 3mths ago, haven't had a problem since then.
gixxerboy
i will be doing this bulb swap tommorrow and if its the bulb i will let you know so i can go to wherever you go yours from. Question. if it's not the bulb and it's the ballast is there a place to buy a ballast cheap instead of the dealership ???
Thanks so much...
QX4dahuneys
gixxerboy wrote: Question. if it's not the bulb and it's the ballast is there a place to buy a ballast cheap instead of the dealership ???
Thanks so much...
Absolutely, if I'm not mistaken, the same seller I went to sells the OEM ballasts for our trucks. One thing though, I doubt it's your ballast, most cases it's just a bad bulb. Forgot to mention, if it's your HID bulb, you will need to replace both side bulbs, if you only buy 1 bulb you will encounter discoloration due to the Kelvin (new bulb vs old bulb). Make sure you order both to replace. Also the seller I know only sells Xenon bulbs in pair and are OEM factory (Phillips D2R 85126<------this is the part no.)
gixxerboy
hey thanks for the info. you have been a great help. do you have the site of info. for the bulbs ?
Thanks
QX4dahuneys
Yes absolutely.....
http://stores.shop.ebay.com/HI...mrsZ1
The seller's name is akinaboy, I bought my HID bulbs from him, very satisified! OEM part. Remember the part you need is a D2R 85126 or D2R 85126+. The one with the plus sign are the ones I have on my truck, they are very bright and clear, no dissapointment. The 85126+ are an upgraded version of the standard 85126. The kelvin on the standard 85126 is 4300 and the kelvin for the 85126+ is an upgraded 5000. Don't worry, the 85126+ won't cause any melting, they are basically the same wattage 35w but with a slighter brighter kelvin temp. Also the 85126+ won't discolorate with continuous use. Your choice of what you want, Let me know if you have any other questions.
BTW, here's a pic of my bulbs "ON", not a great picture because of the camera glare but gives you an idea of what to expect.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Kelvin is color, not brightness.
gixxerboy
Cool thanks. the lights look good. I ordered the +. you have been a great help and i APPRECIATE all the info..
QX4dahuneys
gixxerboy wrote: Cool thanks. the lights look good. I ordered the +. you have been a great help and i APPRECIATE all the info..
Absolutely...glad I could help!
