Simmsled »
https://forums.nicoclub.com/simmsled-u3103.html
Fri Oct 29, 2004 5:44 am
1. yes, that is a great unit2. You should know that your ride is extremely nice and that 45k on a Nissan/Infiniti means that it has barely even lived yet. I would put that unit in my Altima that has 240k miles and be totally happy with it.Also... keep all of your factory stuff in a box somewhere so you can put it back in when you sell your QX4. You don't get any more $$$ for your ride if it has a sweet stereo.3. It depends on the size of the unit. You can put it wherever you can find space. I would say that it would be perfect to hard mount it in the top center part of your glove box (so that it does not move when the glove box is opened). It takes a bit of fabrication, but is well worth it. OEM stuff is usually located in glove boxes if there is no provision in the dash. Since you want it to look proper, (as you should) then the glove box is the perfect place.Good Luck!
