I did change all my vacuum lines today, followed the FSM best I could, look how bad my oem ones were!
I also tightenned the MAF pins thank you very much for that diagram, I thought there was a set screw to tighten them after hearing you say that, but that makes alot of sence, they were fairly tight, but they are tight as heck now
I also borrowed my dads fuel pressure gauge and I plan on T-ing it into the fuel line tomorrow, no store were open with 1/8" npt -> barb fittings. Would it be fine if I spliced it in right here? Im unsure if this is a good spot or not. You mentionned after the fuel filter which is very accessible at the back of the car, or I can splice it in here under the hood.
I think fuel pump is a very good possibility of why I may not be able to go full throttle and get the power I used to have, it seems to just stop accelerating past 4k rpm, very slowly anyways. engine seems to be screaming like it wants to go, but the power just isnt there. Would be nice to know if I have fuel pressure or not
