2001 QX4 Idle problems
lburton
Car: 2001 Infiniti QX4
2008 Infiniti M35 Sport
has anybody encountered this.... while at a light or stopped while in drive, my suv will idle at around 800rpm then will start dipping to then jump back up. this morning it dropped real low to the point that it almost cut off. This happens frequently. it has 175k on it with latest maintenance done of it was the replacing of all coil packs back 1-1/2 years ago. Any help will be appreciated! :gotme
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Try cleaning your MAF sensor. There are pictures on how to do so in this thread, scroll down near the bottom of the first post.
lburton
Thanks :mike !!! taking some days off work for the holidays so will tackle then!
asnorton44
My 01 was doing the same thing, it was the MAF.
lburton
Good! seems like a easy fix.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
It is easy, and cheap, just make sure you get MAF cleaner, and not generic electrical cleaner
Pwnin O'Brien
Yeah, it's likely your MAF (as they've all said). If you're still having the same issue after cleaning the MAF, look for vacuum leaks and maybe do an idle relearn (but that's likely not it).
