I just bought a 2001 QX4. Am very excited to be joining the pathfinder/qx4 club. I am in West Africa (right on the coast) and the car has been here for 3 years, though it was originally in Michigan, USA. It is generally showing limited amounts of rust given the time it has been close to the sea air and in a hostile car environment (compared to other cars I have seen), but I'm worried about the suspension. I'm relatively new to car maintenance but I just gave the car another close look over and read a bit about the front suspension rust recall issue. I've got two questions I was hoping to get some help with:
(a) How can I check the state of my front suspension to make sure I'm not at risk from the problem that led to the recall? I've looked at both front coils and what I can see of the surrounding body and there appears to be limited rust. However some of the casing is concealed by plastic protective sheets. Is there a guide for what I should be looking for and where?
(b) There appears to be some serious rust in the rear, on what I think is the shock absorber casing? I've included some pictures below. Can anyone give me an indication as to how severe this might is: i.e. Do I need to get this fixed asap even to drive on tarmac roads? What about if I want to drive it off-road (hard, very bumpy), will it survive?
If the rear suspension does need work, can anyone give me a rough idea of what the mechanics would need to do and how much it would cost (wherever you are in the world).
Many thanks,
E
https://www.dropbox.com/s/44tceixaj6v6d ... 130134.jpg
https://www.dropbox.com/s/qpnjzw4qtkb0p ... 130210.jpg
https://www.dropbox.com/s/3lgxe8mp89gue ... 130158.jpg
