2001 Qx4 HID Fog light Issue
Fafdawg
Car: 2001 Infiniti QX4 4x4 (Silver) & 2006 M35X AWD With Tech package. (Blk on Blk)
Hello, I was wondering if anybody changed they stock fog lights to HID 6000k.My 2001 Qx4 had stock 4300k HID driving lights and I change it to 6000k and I rely like them...now I'm trying to match the low beam with HID fog light.
Here's what I just ordered today...
http://cgi.ebay.com/ebaymotors...3A317
Please, if anyone done HID Conversion... Help with any Detailed information, Pictures or any problems with installations. Thank you
Modified by Fafdawg at 8:26 PM 7/9/2009
Modified by Fafdawg at 5:37 AM 7/10/2009
Modified by Fafdawg at 10:18 AM 7/18/2009
Fafdawg
Qxxx4, Please help...you might have the information. Thanks
Modified by Fafdawg at 10:20 AM 7/18/2009
UndeGuy
Car: 99.5 Pathfinder (I'm just borrowing it)
Here's a question... are you doing this for aesthetics? or do you plan on more for function than form (making use of it)?
http://forums.corvetteforum.co....html
The original poster makes a rather common observation... 4300k HIDs are brighter and throw light further on the road.
The reason I put this up is because, FOG lamps are "supposed" to cut through rain and fog so you can see the road, when your headlamps are bouncing off the rain and fog. Mostly because it is lower, but it also has a little to do with the color... as you've probably seen all over the internet, yellow doesn't get bounced off rain and fog as much as whiter/blue light. I have 10000k, and it definitely isn't as "bright" as most HIDs, but I find it better than the stock halogens. But when it rains... they get bounced back a lot more than stock halogens.
That being said, if you're going for form (aka looks) by all means go with the 6000k. Right off the bat, they probably wouldn't match the headlamps (not exactly) since your headlamps have had a little time to "burn in." But after a while, they should look pretty close. If you're going for function (making use of them), I'd think 4300k or maybe 5000k would be a better choice, the color wouldn't get bounced back as much as the 6000k, and because it is brighter, it should throw even further than the 6000k. The only issue really is... where to put the ballast. I think someone else has done it (not Qxxx4, he was planning on it if he couldn't adjust the headlamps, but even though he has adjusted his lamps, he could do it later on). Finding a spot for the headlamp was annoying enough, now you have to find another pair of spots for the fogs...
On a side note... I had been "daydreaming" about putting a pair of auxiliary lamps, tuck them away like fogs... but put the most intense bulbs I can find. Their one and only goal... not for off-roading, but if you high beam me for no good reason, I will flash these to make you think twice about doing it again.
Fafdawg
UndeGuy: Thanks for your reply.
Yes, I'm doing it for looks...I'm in VA. We don't get that much fogs Also, my truck came with HID Low beam...I just change it to 6000k and I'm very happy with it. I'm just trying to match my fog lights to HID. I appreciate for all the info and the link you posted. I wish someone would put up the picture of the installation process. I know someone must have done it.
Modified by Fafdawg at 9:51 AM 7/11/2009
Modified by Fafdawg at 10:19 AM 7/18/2009
