vexman2k3 »
https://forums.nicoclub.com/vexman2k3-u132960.html
Sat Aug 29, 2009 3:42 am
This has just happened recently... The car has well over 200K km on it.
It shifts smoothly in the first, and unless I have to hit the gas HARD (but not too hard because it just revs and goes nowhere) to prevent it from taking 3 - 5 seconds to shift from second. Then, once I get to 80kmh, it stays above 4,000 RPM if I want to go fast. So, I can't travel on the highway because my engine will be at 5,000RPM to do the speed limit. The fastest I can go is 130kmh, but that's at almost 6,500RPM steady.
And the worst thing is that since this started, it consumes twice as much gas... as if the fuel economy wasn't s***ty to begin with.
Anyone have any idea what might be going on?
Also, theres some sore of problem with the overdrive function. When I start the car, I have to shift in and out of gear multiple times to finally get the light to go off. If I drive when it's on, it sort of jerks a little when I release the gas pedal. This becomes more noticeable at higher speeds.
