2001 qx4 foglights don’t work
heavy hitter
Car: 2001 QX4
So the fog lights on my qx4 havent worked since I bought it. I’m not even sure how they work. Do they turn on automatically or is there a switch? I swapped the relay under the hood with the one for the a/c which I know is good and it didn’t make a difference. Any ideas?
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
The bulbs are good correct?
The fogs do not turn on automatically. The front fog lamp switch is built into the combination switch. The lighting switch must be in the 2ND position and LOW (“B”) position for front fog lamp operation.
Also did you check the fuses? I believe there are two, a 7.5amp and 15amp fuse for the fogs.
Look in the FSM for more info and wiring diagram here starting on p.70
https://www.nicoclub.com/FSM/QX4/2001%2 ... System.pdf
