2001 QX4, feels like cabin is loosely connected at the back
ulenie
Car: 2001 Infiniti QX4, 2007 Infiniti G35
I just purchased a 2001 QX4...Solid SUV, very smooth ride even for its age. Only problem is when accelerating hard from a stop there is a slight bang sound and a a hard bang feel coming from the back area. Same bang can be felt when breaking hard. Feels like the cabin has too much free play and is sliding around at the back. What could this be? Thanks
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Rear control arm bushings, more than likely.
Welcome to NICO!
ulenie
Towncivilian wrote:Rear control arm bushings, more than likely.
Welcome to NICO!
Thank you for your reply. I will have that checked out.
ulenie
Welcome to NICO!
Just want to update since I solved this problem. It wasn't the control arm bushings, as the shop told me it was replaced recently by the previous owner. So I went back to researching the problem. Greasing up the drive shaft slip yoke, solved the problem. The below thread, goes in more detail on how to diagnose and solve the problem:
post6544030.html#p6544030
Towncivilian
Interesting. I am not sure how lack of grease there would cause this issue, but thanks for letting us know.
ulenie
Towncivilian wrote:Interesting. I am not sure how lack of grease there would cause this issue, but thanks for letting us know.
I guess, that area is loose and by putting a thick grease, it cushions it. This seems to be common issue in the GMC Sierra cars from looking online and some Ford trucks. I am guessing drive shaft will need to be replaced for a permanent long lasting solution.
fueler
Car: 2 Nissan's
2 BMW's
i think i have to check this... ive had a similar clunk for a long time and always thought it was a loose differential!
Towncivilian
You should be greasing the driveshaft at least once every oil change. I usually put in 5 pumps' worth.
