I just wanted to update this thread with a couple things. my passenger side HID bulb went out about a week ago. I called my local dealer for a quote on one bulb and they wanted $274!! I said F-U and started my search online for bulbs. I found a great resource at
http://www.xenonliquidators.com. I purchase a pair, yes two bulbs, for less then $50 shipped! So right there saved myself over $500. I got the bulb in 3 days later, yesterday, so I replaced both driver side and passenger side when i got home from work. it was pretty easy...took about 30 mins. here are the steps....
1. Make sure you disconnect the battery before anything else (you don't want to get shocked by these high voltage babies). If you're replacing the passenger side bulb, take the battery out for more room to work, especially to see what's going on in there (you can undo the air filter case on the drivers side for the same benefit, again--disconnect the battery first).
2. Find and unscrew the round, black, plastic lid behind the headlight, it's up and to the left.
3. You'll see a shiny metal connector with electrical warnings printed on it and Michael Jackson glove looking wiring attached to it. Turn that gently to the left to open up access to the actual bulb (you'll now see the bottom/back of the bulb--a black circle with a small metal tip in the middle).
4. Unhook the two metal braces that hold the bulb in place (push in gently to let wire out--kind of like unhooking a bungee cord or unsetting a mouse trap).
5. Pay attention how the two divots on the bulb case line up with the little nubs at the top of the encasing (you have to put the new one in lining up the same way.)
6. You can now take out the bulb. You might consider practicing the replacement sequence with your old bulb that you just took out before sticking the new one in there--just to get the hang of it so you aren't banging the new one around.
7. Once you've got the bulb back in there just put everything else back in place in reverse order.
8. Wash those dirty hands and try turning on your lights.
9. Go celebrate your automotive victory by driving somewhere at night!
Also here is the link for our bulbs! ENJOY!!
http://www.xenonliquidators.co....html
