elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Jan 19, 2007 5:19 pm
basically what you're going to have to do is take the entire power antenna motor out, take it apart, get all the old antenna pieces out, and then you reinstall the new one... What happens is theres a nylon belt that the antenna works with and over time the belt will break.
its a super easy job, i did it on my Q and it took about 30 mins from drive in to drive out.
