When was the last time you changed your fuel filter? I'd start there.sixty4 wrote:If I am making a right turn for example and step on the gas my tuck takes off but seems to have a couple seconds of acceleration loss. I suspect something transmission as it doesn't seem to want to switch into gear as it should. This is only when I am "really" hiitting the gas.
Any suggests?
I'd say every 30K miles. I experienced the same thing and replaced my fuel filter + cleaned the MAF sensor and it ran like new. Then again my fuel filter had about 175K miles on it.sixty4 wrote:I had my fuel filter done about 2.5 years ago, whats the shelf like on these?
arghhh, back to MAF.I have been putting this off all summer. I also have an issue with the vehicle cutting off at times at stop lights occasionally, seems to be worse in the winter. Basically it idles so low it cuts off, not to big a deal because I am use to giving it a little gas first.Empty V wrote:
Billy
The guy that replaced my fuel filter just cleaned it. What's the maxima hack?sixty4 wrote:
For your MAF, did you do the Maxima hack or get a real one for your vehicle?
Hes talking about using the Maxima MAF I believe its supposed to be cheaper than the pathfinder one but the same.Empty V wrote:
Billy
