2001 Pathy, Rear hatch window, door ajar light
stumck
Car: 2001 Pathfinder LXE
A bit frustrated here! Trying to get the door ajar indicator light to go off when all doors are shut. Isolated it to the rear hatch window, noting that when I pushed on it that the light would go off. I pulled the cover off the inside of the rear door, tightened the latch bolts, as well as lubed it with Si spray. Now when I close the window, the door ajar indicator light stays on. I tried tightening the latch bolts in various positions, at the rear, middle and front-most positions, and the light still stays on. Doesn't go off when I push on the window anymore. Any suggestions?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If you have a torque wrench that does inch-pounds, try torquing the lock and striker to spec, then adjusting as shown.
