tasearay »
https://forums.nicoclub.com/tasearay-u80269.html
Sun Nov 04, 2007 5:24 pm
I have a 2001 Pathfinder LE with a 3.5L. engine. The truck has around 66K miles and has never given me any trouble. Well about 6 months ago it started having issues starting. The problems continued then went away for a few months. Now the problems are back and getting worse. It's completely random and might start fine for a few days then act up, When you turn the key the engine cranks over and over but doesn't fire. If you stop then hit the key and keep on doing that It will start an run just fine. Two weeks ago it stalled while driving for the first time. I had my wife try and start it yesterday while it was acting up. I removed the air filter and shot some carb cleaner in there and the engine fired right up. So I now know it's fuel. Am I safe to assume it's the Fuel pump? or could their be something else to check? No codes or lights are lit on the dash. Also if the pump does need to be replace. How hard is it to replace? does the tank need to be dropped?
Thanks in advance for any help you can provide......
