4xq »
https://forums.nicoclub.com/4xq-u207684.html
Sun May 24, 2015 6:21 pm
I would look at car-part.com. Input your vehicle info - you will need your vehicle production date off of the door sticker - and select transmission as the part.
Trannys are as low as 250.00. You can sort the last column by distance and find wrecking yards close to you. Then just choose the best part grade / mileage / price combo and call them. Check what type of warranty they give you - most are 30 days on trannys I think. Just pull the pan before you put it in to see if there are any indications of problems
Not sure where you live, but you can probably find a straight transmission swap fairly cheap. I personally would not do a 2,000.00 rebuild with those miles, but it is the old question of what appears to be the best way to go from your vantage point.
Hope that helps!
