vonscorpio wrote:Is there a simple trick to getting the old bushings out? The new ones all seem to come in two halfs, which should simplify installation. But what about removal of the expired bushings?
"simple"? yes, a press
If you're not fortunate to have one or know someone with access to one, removal of the old bushings is quite a laborious task. You can do it like saskapath outlines above. You MUST be careful with the sawzall if you choose that route. As saskapath mentions, don't cut beyond the bushing metal collar such that you start cutting into the arm itself. The sawzall will save time tremendously, considering you'll have 8 (all 4 arms) bushings to remove.
The other option is the hand hacksaw. Trust me, maybe on the first arm, you'll feel fine. When you starting attacking the other arms, oh man that sawzall starts to be tempting to run out and buy one :P
Also, when installing the poly-bushings, please consider putting in quality poly-busing grease.
There is possibility that poly bushings may bind and make squeaks and creeks when flexing.
