4xq wrote:Replace the fan clutch & you should be good to go.
There is an old mechanics rule of thumb: Overheats on the highway, then repair the radiator. Overheats in heavy traffic/when idling/at stoplights, then fix the fan clutch. Sounds like you are overheating at slow speeds / stoplights.
You can research how a fan clutch works, but it must be working properly for the engine fan to spin fast enough to cool the engine at low speeds. At highway speeds, the air being forced thru the radiator will essentially cool the engine without the fans help, or very little help.
After you replace the fan clutch expect to hear the fan "roaring" when you first start the truck on a cold morning. This will happen for a couple of minutes until the oil in the fan clutch warms up.
It doesn't need to be an infiniti part, any decent replacement brand is just fine!
Thanks 4xq...my mechanic friend said the exact same thing to me yesterday, and this morning when we talked about this. It sounds like it's the last thing that I can do, that I haven't already done. Oh well...back to the shop again...to pour more money into this {sigh}
I'm really starting to believe that I had multiple cooling system issues that were either right at the brink of failure, or failed at the same time, or when out in secession after my original radiator died back in June and started this entire roller coaster ride. I love my Pathfinder, and it has been a very good and reliable vehicle - up to this point. This overheating/cooling system mess has been unlike anything I've ever encountered with ANY vehicle I've ever owned.
Also, did anyone else also find that getting the air out of the cooling system after replacing the radiator or other parts was a pain in the butt as well?
I'll report back after I have it check over again...and possibly have a new fan clutch put in.
