Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Mar 16, 2008 9:09 am
If you don't have any MIL codes [check engine light], you could pay for a chassis dyno test to read the real world rear power to the tires/road and compare with whats AVERAGE.
Cheaper would be to find an 2001 magazine test and compare accelerations say zero to 60.
"For 2001, Pathfinder receives a huge bump in power, thanks to Nissan's new VQ35DE 3.5-liter, DOHC 24-valve V6. It packs 250 horsepower and 240 foot-pounds of torque when equipped with the five-speed manual transmission (SE only). If you prefer your shifting done by an electronically controlled four-speed automatic transmission with overdrive (standard on XE and LE, optional on SE), the engine makes 240 horses and 265 foot-pounds of torque. That's a 40-percent increase over the 2000's 170-hp 3.3-liter."
"Nissan says the 2001 4WD model with automatic transmission is better than two full seconds faster from 0-60 mph than last year's truck."
8+ seconds 0-60 is what I found
