2001 Pathfinder SE - New Coil Springs
n0reaster
Car: 2001 Nissan Pathfinder
Hey Hello.
Does anyone have a brand recommendation for new coil springs.
Thank you very much for your time and help.
David
Fightingmoose
Car: 2003 QX4
I went with Moog springs and KYB shocks on my QX4 and they seem to be fine.
nickelghandi
Car: 1999.5 Nissan Pathfinder LE 4X4 (rusted out: sold)
2004 Nissan Pathfinder LE 4X4
1998 Volvo S70 GLT
2001 Ford F150 XLT
+1 on Moogs.
They ride like stock and eliminate rear end sag.
hotdawwgman
Car: 2002 Infiniti QX4
I did the KYB and the Moog Springs! So far so good! Been two weeks with this setup and enjoying it.
carldu
Car: 08 Titan
Moog springs plus Bilstein shocks is a good combo also. Bilstein can improve the ride quality of your Pathfinder.
brickbox
Car: 2011 Nissan Pathfinder 4x4
If you're planning on replacing your shocks in the back, just avoid Monroe. I had the shop throw them in my QX4 and they're just squishy. Use the KYB - Gas A Just if possible and you'll be happy.
+1 on the Moogs. They're progressive springs which helps if you load up the cargo area of your truck.
attofarad
Car: 2001 QX4
What Moog part number, and where did you get them?
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
attofarad wrote:
Wed Aug 22, 2018 10:14 pm
https://www.amazon.com/Moog-81115-Coil- ... automotive
attofarad
Car: 2001 QX4
04pathse wrote:
Wed Aug 22, 2018 10:16 pm
For some reason, I only see that listed as a Pathfinder part -- cannot find a QX4 part listed except original. Any chance that the QX4 would be different?
Fightingmoose
Car: 2003 QX4
The Moog 81115 will work on the pathfinder and qx4. They are the same chassis and if you look up the parts on a oem parts finder website for both vehicles you will find a lot of them will have the same part numbers.
Mike94ZLT1
Car: 2002 QX4
What about the front springs?
