jamesonepp »
https://forums.nicoclub.com/jamesonepp-u32038.html
Sun Jan 22, 2006 6:05 pm
Alright! I thought I had managed to *actually* do this on my own - the installers that I called quoted me anywhere from $450 (Canadian) to $712 to install one of these.Hopefully I just spent 3 1/2 hrs and saved a few hundred bucks, but we'll see.
Problem 1) Power Lock and Power Unlock don't work.On the remote starter module, there are two wires: (-) Unlock output (blue) and (-) Lock Output (blueblack). I connected these to a LtGreen and Yellow wires (respectively) under the dash. Here's the thing.. there were TWO yellow wires that came out of one of the white plugs on the SECU. One had two silver dots, the other only 1 (they look painted on). Nothing in the wiring diagrams concerning either of these. I have pin assignments for the SECU (Lock is pin41, unlock pin 30) but I can't see any printed pin numbers anywhere on the plastic.Also, I didn't connect the "Door Trigger" input or outputs - it says that these are for manual transmissions.So why don't my door locks/unlocks work?
Problem 2) Parking lights don't flash. The Green/White (+) on the module I connected to Pink/Blue (+)(from wiring diagram). I purposely didn't connect the horn. The SECU will control that in the event the alarm is set off anyways. However, the parking lights don't flash when using the remote starter when they are supposed to.
Problem 3) the unit came with two remotes. Only one of which seems to work. Working on this one, think that it is a problem with the remote and NOT the module/vehicle at this point.
