Hi,
I have a 2001 pathfinderr (4wd). Recently the rear passenger window has problems. I can control it DOWN from the master switch (driver side) and I can NOT control it UP. But I can ocntrol it up and down without any problem from the local switch (the switch on the rear passenger window).
Does it mean the master swicth is bad? How do I fix this problem?
Any suggestion is accepted.
Thanks in advance.
Ed
