2001 Pathfinder, P1110
Capn Frank
Car: 2001 Pathfinder SE
I have a P1110 code on my Pathfinder. (Intake Timing Control Sensor, Right side).
I understand this is the passenger side sensor, however, where can I find it?
Are there any tips & tricks to replacing it?
I found the part at the dealership - 23731-2y524 for $83.33. Is the trouble code pointing me to this specific part, or will I be 'peeling back the onion' after replacing it?
Thanks in advance for any assistance!
NISTECH
Welcome to NICO Frank.
you might want to take a look at this thread. near the end of it I give a pretty fair explinations as to what is going on.
zer...76338
Capn Frank
Thanks, I read that post a few times.
Coincidentally, my SES light went off today on it's own. Using the logic you told us about in the above-referenced post, should I assume that the solenoid is probably going to be the culprit if I get the same error code again?
NISTECH
actually watch for the light and the point in which it comes on next time. If it comes on imediatly on start up of the vehicle before driving its the sensor, if it comes on while driving it could be either part, but a little hint if it is a solonoid would be the exact driving condition your under when it does wink on. If you are in a mild load condition,like climbing a slight grade I mean very slight and your throttle has been steady for approximatly the last 20 secs when the light pops on it is likely the solonoid.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
Thank you very much for that explanation
Could someone please tell what "solenoid" Syeve was talking about??
Possibly a part number and maybe an FSM reference so I can get an orientation of it in my engine.
P1110 code is kicking my butt
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
http://www.nicoclub.com/FSM/pathfinder/2001/ec.pdf Diagnosis starts on page 448, and it looks like a real pain. I agree with NISTECH's advice and see when it come on after resetting it.
CanuckQx4
Well Im almost sure its the solenoid, not based on any knowledge of my own, as I replaced both sensors already which got rid of P1135/P1145. So I think after reading all the threads mine would be the solenoid
My CEL doesnt come on right away when the car is started, it only comes on after 10+ min of driving
I just dont understand where the actual solenoid is on my engine, and its part number
CanuckQx4
After reading a bit of the FSM link you posted (which Im not going to lie is way above my knowledge level). I think there may be 2 solenoids? One per bank??
If thats the case can they be swapped? See if I get the code on the other bank?
