wait... that thermostat is only there to warm up the engine quickly to the operating
tempature. when the engine is cold the thermostat is open, when the engine reaches operating temp the thermostat closes.
i dont think it would matter if it stayed open , it all loops through the radiator.
i could be wrong though
-air bubbles are very likely , due to engine design. that's why nissan put a air bleed near the firewall
-just looking though the radiator opening is not gonna tell you if its clogged.
-i thought the fan clutch was supposed to spin freely when the engine is cold?
-did you open the air bleed located near the firewall ??? when i did a coolant flush it took alot { about a gallon and a half } and then some more.
-according to the nissan factory service manual its Coolant capacity (Without reservoir tank):
9-1/8 quarts { Ma-16}
-if your main thermostat is working {should be the first thing you replace anyway} then you have an obstruction somewhere or the water pump is
done. your coolant is not cycling completely .
