Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Jun 16, 2008 7:43 am
Wow, most expensive oil change ever.
You can do this.
If it ever happens again, ram a screwdriver through the thing if you can't get it off and use it for leverage. Have your catch pan ready because it'll be a little messy.
The trick to getting these off is not to put them on so tight to begin with, and to ensure you take some oil and oil down the rubber ring on the filter for a good seal and so it doesn't freeze to the filter mount.
