2001 Pathfinder O2 sensor
nicv21
Car: 2001 Nissan Pathfinder
I'm trying to replace the 4 O2 sensors on my Pathfinder, and the ones I've received, the terminal blades are vertical and the ones on my vehicle are horizontal. And yes I can cut the wires and solder and shrink wrap the old connectors, but am I possibly ordering the wrong ones.
My pro date is 03/00, so I've even tried to call it a 2000. I called Nissan and they asked my if the VIN had a 7Y instead of something else
any suggestions and I will be grateful. Also I'm looking for Bosch, buddy told me either Bosch or Denso. Anyone have a preference?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Use the factory part numbers for your search and not make-model-year. Visit NissanPartsDeal.com and enter your VIN, that will get you the correct part numbers for your particular ride. Then use those for googling or in RockAuto's Part Number Search tab.
nicv21
I tried the Nissan parts deal site and it only listed one O2 sensor and for $233 !!! And the 2 others were cut and splice.
VStar650CL
Technical Expert
Just get the part number from the site, you don't need to buy it there. Use the p/n to cross-reference aftermarket parts. When an aftermarket supplier claims exact equivalence, you can be about 99.5% sure it actually is equivalent.
