2001 Pathfinder hub bolt
Acinonyx
Car: 2001.5 Pathfinder SE 3.5 4x4
Hello, I took off the wheel center caps on my pathfinder and saw that one of the bolts and nuts on the front hub (4x4) was missing. Can someone tell me how serious this is? There is a wheel wobble at highway speeds which I believe is a missing wheel weight but I wasn't sure if this could affect anything. I'll try to post pictures.
Acinonyx
after looking in the service manual it appears the part that is missing the nut and bolt is called the drive flange if this helps
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Welcome to NICO.
Upload your picture to www.imgur.com and it'll give you copy & paste options to post the image here easily.
Acinonyx
Here's the image
<img%20src="http://i.imgur.com/r6QSx.jpg"%20alt=""% ... r.com"%20/>
<img src="http://i.imgur.com/WHz6z.jpg" alt="" title="Hosted by imgur.com" />
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Acinonyx wrote:Here's the image
Chuck
Acinonyx
Thanks for getting the images chuck. I've been using my phone for posting cos that's where I took the pictures, would I need to use a computer for that?
Chuck Tribolet
'87 Chevy Corvette
No. You just wrap the right stuff before and after the URL and it imbeds it. It's kinda hard to show you the right stuff because then it tries to imbed a picture.
Chuck
Acinonyx
Ok, so does anyone know whether I should be to concerned? I tried looking in the service manual on this site and I only see the nut, I don't see what pat the nut is threaded on.
Acinonyx
I don't see anything in the fsm, but would 40060e "pathfinder stud" on this website be the part I need, and how would this be installed? I only see the nut in the fsm. http://www.nissanpartszone.com/componen ... 294_2.html
Towncivilian
It looks like 40060E (stud) and 08911-6081A (nut) are the parts you'd need. Please provide your VIN and I can look up exact part numbers for you.
Where are you located specifically in Florida? I'm in Palm City, about half an hour north of West Palm Beach.
Acinonyx
I live in clermont, 30 minutes west of orlando. I don't know the vin of the top of my head but I do know it was one of the later 2001.5s that had the new smart entrance control unit as specified in the electrical section of the fsm
Acinonyx
So I looked up the vin and its the right part, but the el section of the fsm says that after 584967 have the new entrance control and I have one that starts with 6, does this mean I have a 2001.7? Geez, how many model years were there in '01?
Towncivilian
Heh, no, it just means you happened to get a 2001.5 with the new SECU. :)
I'll need your VIN regardless to look up parts. I'd use my own but I've got a 2WD and the part numbers are not applicable for my vehicle.
