VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Fri Sep 06, 2024 8:14 pm
I learned the value of chassis ears back around '14 from a Nissan DTS. He got sent to us because of an early gen5 Altima that was making the strangest intermittent "thunk" out of the lefthand floorpan. There was no pattern to it, you'd hit the brake or hit a bump and get the noise, then drive for miles and not hear it again. It was loud and you could feel it in your feet. Nothing was the slightest bit loose in the steering or suspension, we had already done a chassis relaxation and even tore the dash out to make sure the factory hadn't left something in or behind the HVAC. We were at wits' end, and the owner was going nuts about it. She was talking lemon law and buyback, so it got serious.
Enter the DTS with a set of chassis ears. After two full hours getting a total of three thunks and relocating the ears twice, it seemed certain the noise was coming directly out of the subframe. Broken weld, we wondered, except it didn't sound metallic. Hmmmm.
"Drop it," the DTS instructed. "Clock your time, I'll see that you get paid." So here I have it lifted and I'm running the left rear bolt out of the frame, and I hear a clatter at my feet. The guy in the next bay lifts an eyebrow. "What was that?"
I look down and between my shoes is an acorn-sized rock. Inspecting the top of the bushing sleeve, there's a visible scrape clear down to the metal. Turns out this woman lived on a gravel drive, and somehow that little rock got trapped between the bushing and the body, completely invisible from underneath the car. Every time it rolled around to the wrong spot and the bushing compressed, the floorpan said ouch. Without the chassis ears telling us definitively where to look, I'm sure we never would have found it.
