2001 pathfinder codes P0303, P0325
chucknissan
Car: 2001 nissan pathfinder
my pathfinder is starting to rattle, especially at 50-60 mph. Per autozone, these are the codes. what do they exactly mean , and how much to repair. And is it possible for a novice to repair . I believe one issue is the knock sensor. thanks for help
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Per this, your codes mean:
P0303 Cylinder 3 Misfire Detected
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
Do you have the 3.3L or 3.5L?
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Profile says 2001, therefore 3.5L.
Get an FSM, you can find them as PDFs on the web. It has a diagnostic procedure.
P303 seems to turn out to be the coil (each cylinder has its own). The good news is #3 is relatively easy to get it. But I'd check the plug first.
P325 could be knock sensor or wiring. FSM tells how to check it out. You'll need a good digital ohmeter that can read greater than 10MOhm.
Chuck
Towncivilian
The FSM for the 2001 can be found here.
chucknissan
thanks so much, chuck & towncivilian!....do you think I should first, just try and replace plug and coil of cylinder 3 , before I delve into replacing the knock sensor?
Chuck Tribolet
'87 Chevy Corvette
There's a debug procedure in the FSM. I'd do that before I started throwing parts at it. And I'd pull the plug and have look at it. MMM, I wonder which other cylinders, if any, have the same coil as #3. You could swap coils and see if the bug moves.
Chuck
asnorton44
Car: 2001 Infiniti QX4
Cylinders 2-6 are the same, cylinder 1 is not.
Chuck Tribolet
'87 Chevy Corvette
asnorton44 wrote:Cylinders 2-6 are the same, cylinder 1 is not.
So swap the #3 and #5 coils and see if the P0303 turns in to P0305. If it does, it's the coil.
Chuck
chucknissan
thanks so much for info. mechanic installed new coil and plug on cylinder 3 to clear code p0303,,but service engine soon light still on for code P0325...knock sensor?...what should I do? my mechanic says , just drive car and go from there. It is driving normal for now. how can I clear code P0325?
asnorton44
