bkiser482 »
https://forums.nicoclub.com/bkiser482-u247667.html
Sun Feb 08, 2015 2:21 pm
Hello everyone,
My parents have a 2001 Pathfinder SE 4x4 and it has been having allot of trouble and I am trying to help them. First off, the parts that have been replaced since it started running very rough suddenly, and then wouldn't start at all are: Idle control valve, Throttle Position Sensor, Mass airflow sensor, ECM, 3 coils, Battery, and entire Throttle body Assembly. Now it is blowing a 10Amp fuse when trying to start(still no ignition whatsoever). My father says the fuse is marked ECCU2, I am over 3 hours away so I haven't seen it yet, he says it will turn over fine but not even a putter of ignition then within 10 seconds it blows that same fuse every time he tries to crank. They also replaced Crank position sensor and cam sensors as well.
Any Ideas or help would be much appreciated. Thank You!!
