Wow.... 100 month warranty. I've never owned a car anywhere NEAR that long. I just replaced mine last week. Extremely simple. Just swap it and reset your radio stations.dkl wrote:Thanks a lot guys. I plan to get it at COSTCO because it has a 100 month warranty and a 36 month free replacement.
You can go to any auto parts store or even Walmart and pick up a can of battery terminal spray which you spray on the terminals to prevent corrosion. This stuff is much cleaner and easier to apply than Vaseline. I use it on my batteries and I've never had corrosion, the terminals still look like new.dkl wrote:Finally replaced the battery with a Costco 100 month battery and it works great.
Question: Read somewhere vaseline should be put on terminals to prevent corrosion. But others say not to because vaseline could liquify under intense heat and cause problems.
Do or don't do??
I've got a good sized sound system and have cranked it for hours on end while working on my car and the YellowTop has always come through. They're perfect for sound systems.Natedogg1701 wrote:if your just replacing the battery and have no heavy loads on it, like a sound system or something, then ya a yellow top is good. but I ate through three yellow tops b4 i got the battery i have now. Theres an company called Xstatic and they make what they call batcaps. they arent liquid acid batterys, their actually a dense gell. I got the batcap 2000, its 2000 cca (cold crank amps) and weighs about 30 to 40 lbs, and will run you about 320 buks. but for me its way worth it.
I use silicone spray and it's worked well for me.dkl wrote:Finally replaced the battery with a Costco 100 month battery and it works great.
Do or don't do??
I've used... nothing!dkl wrote:Question: Read somewhere vaseline should be put on terminals to prevent corrosion. But others say not to because vaseline could liquify under intense heat and cause problems.
Do or don't do??
