KILLERME »
https://forums.nicoclub.com/killerme-u137481.html
Thu Jul 02, 2009 4:37 am
If this is a VG33 engine, Most comon is crank sensor , which is the whole distributor. If definatly no spark. clear fault codes by disconect battery then try and start again, then check fautl code, if coming up crank sensor that will be problem, knock sensor is common fault, knock sensors dont like heat under intake on block, 140k plus they start to f*** out, knock senson will not cause any noticable engine loss in performance, but should be replaced, big $. check all fluid levels, check for spark while cranking. To do this remove one plug lead from spark plug on engine, jam a spare spark plug or screw driver in the lead hold close to metal part on engine. while cranking or runnig this should spark like a heart beat. If got good spark, check leads on cap haven't been put in wrong place. all it takes is for one lead mix up and anything will run like s***.Got the spark and leads right, then I would check fuel pressure with gauge, if haven;t got one squeeze fuel line from filter to engine then turn key you should feel it prime and go hard. If got running at idle squeeze hose and see if going soft when engine starts to die, if so you have fuel pump or fuel relay problem. if ok move on, unplug air flow meter and try in fail safe mode. It will let you rev engine to 2000rpm only, but should be smooth reving up to those revs, if it is faulty airflow meter. If no change when unplug air flow it Aint airlfow meter.Good luck,
