fleurys »
https://forums.nicoclub.com/fleurys-u158666.html
Wed Sep 22, 2010 5:35 am
in these kind of problems you have to proceed by elimination or else you'll spend alot of money... To see if it has anything to do with your front drivetrain do these steps one at a time and test before doing the next one:
1) remove the front driveshaft
2) remove left half-shaft
3) remove right half-shaft
if it stays the same, then check if you do not have an engine or trasnmission mount that is broken.
Is the vibration getting worse with speed or engine revs ? does it calm down between such and such mph ?
all 3 tests can easily be done in an afternoon.
If the problem persist , it could be as simple as the rear ujoints. You can remove the rear driveshaft and see if the ujoint moves freely or has any play in it... You don't need alot to create a vibration...
Hope this help a bit.
