2001 path le with bose cd changer problem
Post all your Nissan electronics, car audio and stereo questions here!
ants07versa
Car: 2007 versa s 4spd auto
i have a 2001 path le with the bose and 6 cd changer in dash the problem is the light on 1 stays red and will not load now i bought this car used and i dont know if there is something jammened also the error 2 comes up on the screen when playing around with it also the radio gets really bad recption
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
There is a sticky at the top of the forum that has info for a place that will repair it for you. There really isn't anything else that you can do, other than replacing it with something else.
ants07versa
does any one have a good place to start with the bad reception
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Do you have any am reception?
ants07versa
yes am sounds good fm comes in crapy
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I did some reading and apparently the FM antenna is the one that is in the windshield. Double check that someone didn't scrape off an inspection sticker or something and break the wire trace. Perhaps the windshield was replaced and they didn't use the right window or didn't reconnect it?
ants07versa
does any one know where the connector is
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Never actually played with one, but it looks like it's on the driver's side of the windshield. Possibly under the pillar molding? Follow the pillar trace and it should lead you to it.
ants07versa
has anyone ever used a aftermarket antena for the fm
