2001 path fan wont blow
mld599
Car: 2001 Pathfinder
I have had an issue in the past about the fan blowing on high speed only and have fixed that about 6 months ago. Now, this morning, the fan wont turn on at all. Anyone else had this problem? I can change the temp with the controller including a/c but no air.
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
I think you need to change the blow motor. You can usually get used ones from scrap for cheap. its a easy fix
jetroy240
Car: S13, AE86
New blower motor & control amp must be replaced as a pair when blower motor is on high speed only, these are superceded parts. If fuses are ok, chances are the control amp (blower resistor) failed again.
