loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Mar 05, 2010 11:25 pm
The rattle may be due to failing suspension and/or engine mount. On cars equipped with electronic engine mount, failure of the actuator may 'fry' the ECM. A failing MAF may or may not generate a CEL. In most cases, cleaning the MAF sensor and connector will fix the problem. Otherwise, the MAF sensor has to be replaced due to internal problem (cold solder or failing board).
The catalytic converter, OEM part, may be expensive to replace and there are 3 of them for 00 Maxima and beyond - Banks 1 and 2 Pre-Cat and Main Cat. Problem with cat usually is associated with owners neglecting to replace a defective O2 sensor. With the O2 sensor out, the ECM causes the engine to run rich (poor mileage) and unburnt fuel may accumulate in the cat and even ignite, destroying it.
Again, it's more of a buyer preference and which one you are confident in owning.
