ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Feb 14, 2011 1:28 pm
Since money is tight, and what else is knew?
Let's start with #4 plug and work backwards. Plug, wire, coil, interconnects, transistor. Likely not transistor, but check plug and HT lead, then the distributor. Inside look for dirt, dust and clean, clean underside of cap. Stop
Faulty part in fuel tank could cause rough idle if gas is not getting through, so verify pump, fuel filter and fuel rail. Stop
At 80K miles the O2 sensors are slow acting, the rich to lean mixture may be all over the place (miss fire?) Pull all plugs investigate, cleanliness colour tan amount of crud let us know. Stop
The front 2 O2 sensors are probably slow causing the back 2 to eventually report catalytic problems, but the front must be good before playing with the exhaust downstream of the front sensors. At 80,000 m has the vehicle had O2 changes? Stop
High fuel pressure is rare, the regulator should be tested but test the fuel rail no guessing allowed. Guess what is wrong and you will be in the poor house, know what is wrong by investigating, testing, so that means money has to be spent renting or buying test equipment or using what you have to find the answer. Don't guess!
Vacuum leak at what location working what system?
Any leaks to the tank should be caught by the evap sensors
Vacuum leaks at the motor can be tested with a source of Hydro carbon that will speed up the engine, propane for example.
The stop in this write up is a section for you to perform the tests.
Vacuum is created when the pistons are drawn down, a vacuum container in line is to help maintain vacuum because vacuum in an engine is up and down as the pistons at differing times draw .
Fuel pressure at 40 PSIG on the rail feed and a bit less on the rail load must maintain a minimum pressure to the fuel injectors.
The fuel injectors will oscillate and the spray pattern should be tested and the spray pattern changes as to motor conditions via the ECU.
Sensors like O2 are very sensitive to voltage and the voltage changes around the threshold voltage.
I understand saving money, but there are times because of technology that you could make the condition worse.
The work outlined requires testing equipment and anyone willing to work on their vehicle should have a minimum set: As far as testing goes:
Spark tester
Vacuum gauges, gas pressure gauges
Timing light
Multi meter
Wire markers
Compression tester
Remote starter switch
Feeler gauges flat and wire
Tire pressure gauge
Battery hydrometer
Anti freeze hydrometer
Battery charger able to charge at 3 rates, trickle, 10A and 50 A for equilization
Doing the work is satisfying when done and done right, but it will cost you the tools, hand tools sometime the specific tool and testers and the longer that the keep a vehicle the more into it you will get. With time comes confidence and learning. Good luck
