Mike W. »
https://forums.nicoclub.com/mike-w-u275015.html
Sat Nov 16, 2019 10:28 pm
Knowing how some cars work, but not Nissans specifically, I'll mention this.
If you removed an arm from the wiper motor, which would drive the linkage and the wipers, you probably didn't get it back on in the right spot. The park function is typically built into the motor assy. If applicable, remove the arm from the wiper motor, let it cycle thru without anything attached, then with the wipers at the park position, attach the linkage. Test it with the wipers in the raised position just to be careful in case I'm full of it.
