so i see there are quite a few topics on this have done the tests i have seen on the site have not figured it out yet and am about to pull my hair out.
here is the short version of the story of where i am at. the valve cover gaskets on my pathy where starting to leak oil on he exhaust manifolds so i ended up replacing them. not as bad of i job as i first thought and took my time to make sure i didnt miss anything.
after getting it all back together and double checking all my work as i went i started it up and let it idle to check for any leaks all was good after a couple minutes the engine light came on so i checked it and got p1130 swirl valve control so i took to the internet to see what others have done.
so far i have checked all vacuum lines for blockages all was good. put a vacuum gauge on and was able to open and close the swirl valves with that. moved on to testing the swirl valve solenoid by putting 12v to it and it worked. checked the power wire at the swirl valve plug and had 12v there as well.
the rpm will also jump up and down if i hold them around 1500 or so. about a 400rpm jump.
only thing i can think is the ground may have been damaged when i moved the harness to gain access
2001 nissan pathfinder
3.5
auto
4x4
thanks in advance
Dan
