NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Sep 01, 2005 6:12 pm
To answer your initial question, yes a bad Idle control valve can take out the ECU. We have seen numerous ones fail in such a manner but never twice in the same visit. You may have something going on with the wire harness. I have done at least 3 combos and one just the idle valve as it was repaired early enough to keep the coolant from causing a major short in the idle control valve. What happens is the valve develops a coolant leak into the electronic circuitry to cause it to fry the ecm since it sends voltage directly to the IAC driver. The coolant leak though is small enough it isnt really detectable unless you notice you have to add coolant to your resivoir to keep it at a solid level. You would be adding about every 500 to 1000 miles.
Wes the quality of nissans ECM's has drastically dropped since 2000. I cant tell you how many sentra ECM's I have done I dont have enough fingers and toes to keep up any more. Done several ECMs on other models as well.
The fact you had to go back for a second round suggests you may have a wiring issue as well.
