346ci »
https://forums.nicoclub.com/346ci-u164732.html
Fri Jul 23, 2010 9:23 pm
Start with checking the NATs system. That is built into your key and has to be programmed to the car by a dealer. If the red light on your dash(top of dash) is lighted while cranking, you have a NATs problem. The key could lose program or the unit in the dash is screwed up. This system works by killing the ignition system, ie no spark.
Those cars could flood in any type of weather. To check this, hold the throttle wide open while cranking. If no help, move on.
The MAF sensors usually caused poor running, I don't remember a 3.0L not starting due to a MAF. It's better to have a known good spare to check these.
I'd then check the crank sensors. The POS is near the transmission cooler lines going into the trans. The reference sensor is to the right of the oil filter.
