Please see my response below, one at a time. Please do the most simple and cheaper ones first before going into complicated/expensive items.
I have a few newbie questions for you based on about 3 hours of research today. You answers I will also pass on to mechanic.1. Could the O2 sensor fuse be blown in the fuse panel?- Not likely. The fuse is primarily for the heater to warm-up the sensor. If there is short/open circuit in the heating element, it will trigger a different fault code, e.g. P0161. But there is no harm in checking the fuse.
2. How does one best check for a vacuum leak or an exhaust leak specifically without any codes?-It's already in my previous answer. Use a carb cleaner to and spray it on the vacuum tube/hose/fitting on the air intake (the area from air filter box to the TB going to intake plenum). If there is a leak, the carb cleaner will make the A-F mixture rich and the engine will tend to surge. For exhaust leak, car must be on a lift and check for for obvious cracks/holes or loose fitting on flanges, etc.
Please go thru the Maxima/I30/I35 FAQ 'sitcky' (link below) as there are a lot of "How To's" there, including Fuel Injectors.. But do not use the one for O2 sensors as the procedure there applies to Federal Configuration with 3 O2 sensors- 1 on each bank exhaust pipe and 1 downstream of main cat. (99 CA-Config and 00 and beyond Federal-config have 4 O2 sensors). Your car is 5thGen Maxima (200-2003).
zerothread/219453
3. I guess it is possible a coil could be bad or an injector be bad. -We can do this ONLY if the preliminary procedures I have given you did not work. These 2 items are more complex. The fuel injector problem will typically show up in various RPMs. Basic checking used is the click-test (use a mechanic's stethoscope or long screw driver) and listen for clicking sound coming from the injector. Additional testing and replacement procedure is in the FAQ sticky. As for the ignition I just sent another member a procedure to diagnose ignition problem. Below is the link. Look for my response to SVTCOBRA.
zer...-code
I read how to test coils, but perhaps you have a better way.Also is there a way to test an injector? -see above.
Or is it all in the manual pdf you so kindly gave me a link to??If you lived near Charlotte, NC, I would bring the car to you.Is it possible for a small fee for the mechanic to call you if he has any questions problems next week? (answer via private message please
[email protected])
-The manual is in PDF so you can print the relevant pages, especially the Wiring Diagram (HO2S2-B2) and some of the testing procedures. This is the same FSM (Factory Service Manual) that is used by Nissan technicians.
-This is NICO and we provide assistance for FREE. All we ask from members is to buy parts from our sponsors so we can keep this site working, e.g. "infinitipartUSA.com" which sells OEM parts @ 25% off MSRP. We also encourage members to have their friends with Nissan/Infiniti cars to register with NICO. I usually respond this forum at night time and during weekends. So if there is a query, post it here and I'll try to respond ASAP.
One other thing I forgot..Is it possible that Nissan who did the ECM update to be safe (for my independent mechanic) SHOULD HAVE put the ECU into self-learn mode?Not sure that was done. -They probably just reset the ECM or maybe an upgraded program. The ECU (or ECM) has self-learning feature so it can make changes when components, especially emission-related are replaced. Just drive on city streets for several minutes and then on the highway and do several WOTs (Wide Open throtyle, but do not overspeed).
Here are some things I thought about after reading about 240 posts prior to your reply. Any comments???
I think there is an O2 sensor fuse, check for such in fuse panel-may be more than 1. -see answer above
Ensure ground wire is connected to Cat. -The O2 sensor housing is grounded to the cat. The cat is connected to the engine thru the exhaust manifold. There could be additional ground points. But it is very important to check the main engine harness ground point (near intake plenum) as poor connections could cause starting and stumbling issues.
Check to see that the connectors on MAF sensor are registering voltage before replacing sensor. Could be a bad connector. Please see thishttp://en.allexperts.com/q/Nis...F.htm-I already gave you basic cleaning and testing procedure. Just a simple description, the MAF has a heated sensing element whose current changes as a function of air mass entering the sensing element. DO NOT TOUCH THE SENSING ELEMENT. The higher the air flow, the greater is the cooling effect on the sensor so the current is increased (higher voltage across) to compensate for the heat loss. When taking measurement, make sure you use the chassis ground (and NOT THE MAF SENSOR GROUND as it can damage the sensor circuit). Also, the engine must be at no-load condition (AC off, no lights/radio) and shifter in NEUTRAL. Use Pin 1 (W-white wire, which is connected to ECM Pin 61)) and measure the voltage with respect to chassis.engine ground as follows: Idle = 1.2-1.8VDC; 2500RPM=1.6-2.2VDC. Refer to page EC-134 (P0100) for detailed info.
Check to see if any cracks in Cat or Manifold - covered above
Please Replace MAF sensor - do not replace unless confirmed bad. An OEM part is expensive but a refurbished one from Napa is @ $70.
Definitely Remove and Clean Throttle Body, I would appreciate it. -already suggested before
Definitely Clean Idle Air Control Valve for carbon build-up - already suggested before
Prob good idea to check the 6 engine coils, can be done with a meter or something per the below - I provided the link alreadySee
http://www.ehow.com/how_491236....html
******Did Nissan put car in self learn mode after programming ECU? If not, I was told they should have and this could be a problem. - discussed before
-------------------------------------Step 2
Replace Throttle Position Sensor? possible but usually shows as a stumbling over a wide range of RPM.
Check EGR Valve, clean if necessary - testing and cleaning can be done together with the IACV cleaning.
Vacuum leak can cause a stall - already discussed before
----------------------------Step 3Clean manifold for carbon build-up - that's gonna take a while, if you want to do that. I don't think that is the problem right now.
Replace crank/cam position sensor - possible but should show up on a wide range of RPM. Car may not even start.
Replace other 2 O2 sensors - No need unless the fault code is specific to that sensor.
Replace CAT????? <---------------- Get another car after get a job-am out of work - LAST RESORT DUE TO EXPENSIVE PRE-CATS AND CAT. There are 2 Pre-ccats (for Bank 1 and Bank 2) and 1 main cat (rear) and OEM parts are really expensive due to precious metals inside (Platinum, Palladium and Rhodium. Aftermarket parts are cheaper but don't last long. A continuous RICH mixture will destroy the cat (unburned fuel will ignite inside the cat and destroy the honeycomb)). If Bank 2 Cat is bad, the catalytic oxidation/reduction and O2 storage capacity will be impaired. So the Rear O2 sensor and the Front O2 sensor (if they are operational) will have similar voltage swings (same level of O2 detected by both sensors).
Whew...this is the longest one I've ever done so far...
