2001 Maxima - Turn Signal Relay Issue
s361673
Car: 2001 Nissan Maxima
I have a 2001 Maxima and the left turn signal flashes very fast. All bulbs are lighting up, so my theory is that the relay is going bad.
I am trying to replace the relay, but cant find it. I have looked under the hood and under the dashboard; I can hear it under the dash but it must be behind/under something else because I cant see the relay.
I dont want to tear the entire dashboard apart to replace this relay. Is it accessible and easily replaced? Are there other things I should consider replacing while I am at it?
Thanks in advance.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Have you replaced a bulb on a signal lamp lately. An out of spec bulb can give you such problem. If not, then it is the Combination flasher Unit, connector M21, typically installed under the instrument panel
