NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Jul 18, 2003 2:27 am
well drjohn is but isnt correct. i looked on assist. there are 2 tsb one for the 420 code which is for catalytic efficency NTB00-070a which is mearly a reprogram of the ecm. the o2 tsb is NTB01-016B. both of which are covered under the emissions warrenty. but here is the catch. I pulled out the warrenty book yesterday and checked the covered warrenty items. here where I live it is covered to 50,000 miles(california emissions warrenty) but apparently the rest of the country it is only 36,000 miles. so it looks like the dealership is correct about it not being covered where your at. but you now have the exact tsb numbers they said did not exist. the o2 tsb requires replacement of the bad o2 and an ecm reprogram. but the ecm reprogram for either tsb would cover both since there is only one updated program for the car. so if you replace the o2 yourself they should charge you no more then 1 hr labor to do the reprogram.
