loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Mar 25, 2010 5:45 pm
Check oil level with engine cold. If you're lucky, the oil could just have been overfilled or inadvertently got into the exhaust. Otherwise, you may have leaking engine oil seals (worn valve ring/seal) indicative of abuse by PO. If you're burning oil, exhaust will be bluish. If you have this problem only on start up, seals are partially worn but if i is continuous, seals are in bad shaoe. You need a trusted mechanic/shop to look into this as the repair can be expensive.
Did you get extended warranty when you bought the car?
